Cesspit
C
CentralCommuter
Apology accepted.
Rusty Nails
Country Member
I had no idea of the existence of NCAP, but when I did, it struck me that it was a place where certain opinions, behaviours, topics were kept so they did not detract from the main site - like the function of a cesspit. By pointing out this similarity, I seemed to cause offence.
It does serve a similar function though.
And so you found your way here!
briantrumpet
Timewaster
Not my area of expertise, but, isn't that a septic tank, rather than a cess-pit?
Nor mine, but I think they both stink.
briantrumpet
Timewaster
From Googling:
A cesspit, or cesspool, is a waterproof and sealed tank that is buried underground to collect sewage. It is typically made from fibreglass and has a single access hole at the top. The advantage of a cesspit is that it provides a solution for waste disposal to homes that are not connected to the main drainage system.
A cesspit can also be used for temporary waste management such as on a building site or for seasonal use such as on campsites. Natalie Mitchell, property and construction expert at HomeHow.co.uk, says installing and removing a cesspit is fairly straightforward.
“It can be used in areas where a septic tank would not work well, such as in non-absorbent soils," she explains. "There are disadvantages to having a cesspit. It simply holds waste; it does not treat it or break it down in any way. A cesspit also has no outlet pipe and so will need to be emptied on a regular basis.”
Psamathe
From Googling:
When I lived in France mine was made of concrete. Didn’t comply with the "new" regs but they were only gradually being introduced.
Weird but local commune maire organised a commune meeting for lecture on new septic tank regulations with Q&A then mingling with refreshments. Weird but after formal part maire had noticed me and sought me out profusely thanking me for attending. My attending really seemed to have meant a lot to him (I lived full time, not holiday home and was only Brit in the region).
briantrumpet
Timewaster
Fortunately my commune had already been de-septic-tanked (decesspitted) when I bought my house: the commune has a three-pool reed-bed filtration system.
Psamathe
I ended-up moving back to UK just as regs were starting to be enforced. I suspect I'd have had to go for one of those micro processor things as house was only 1 ft above river level upstream (watermill with river running literally through the house). Micro thingys are expensive (though will work safely even when flooded underwater). Also over 1 km from nearest house, 2 to commune.
briantrumpet
Timewaster
Ah, tricky. Yes, I think my hamlet was done en masse... a relatively straightforward process, I suspect, given the layout & situation, all managed by the mairie.
