EU & Brexit Bunker
PurplePenguin
You'll have to argue with the paper rather than me - their credentials are more impressive than mine, despite my extensive participation in the CS thread.
But this graph might help to explain - it looks like we haven't even kept up with the average (if I'm reading it correctly), let alone the better ones.
Usually these sorts of things just blend a bit of EU growth with some US growth and say that's what the UK would have done i.e. massively outperform all European peers.
I actually agree with First Aspect on this one.
briantrumpet
briantrumpet
Pharaoh
Well, when a paper comes out written by renowned economists that critiques/undermines the conclusions of this one, I'll be interested to read it and its rationale.
briantrumpet
briantrumpet
Pharaoh
No, but they had differing impacts on different countries.
And could that have been because (for instance) they were still members of large trading blocs? I'll accept that the war and covid could not specifically have been foreseen as the hard Brexit we ended up with was being formulated, but equally withdrawing from the EU was inherently risky. Sure, it was bad luck that they both came along the moment the UK left, but I can't see anything that left the UK inherently more exposed to covid or the war - for instance, Germany's hyper-reliance on Russian gas was a severe risk.
briantrumpet
briantrumpet
Pharaoh
There's a difference between the general idea we would have been better off, and postulating the number in that paper. Which do not pass the sniff test.
The only hypothesis that would make any sense is that the EU growth has been damaged significantly by Brexit as well. But you'd expect that to be proportionally a lot smaller.
briantrumpet
briantrumpet
Pharaoh
Well, if your sniff test is justified, I expect the paper and its authors to be speedily ridiculed for their poor assumptions/methods, as that's what academics do to each other.
  • Like
Reactions: C R
PurplePenguin
I skimmed the paper quickly.
They caveat their macro analysis due to the impacts of covid. As a result, they attempt to use some micro analysis which they typically do not do - this shows a smaller impact.
They use the group of countries I expected them to (EEA, US, Canada and Japan) then find under performance based on how much weighting is given to the US. I didn't see any discussion on whether the extraordinary levels of US growth were likely to have been replicated in the UK. Some of the US boom has been due to high gas prices and technology companies.
Is this the missing 4% of growth that would have propelled the UK to vastly outperform all its peers?
Numbers often lie by not telling the full story. Trade deals under the EU before Brexit where very slow, they accelerated it, and also normal poeple/poverty rates have gone up across the EU.(just as in the UK) so somewhere in the % someone has been doing the dirty with numbers... Maybe it has something to do with the EU's increasing debt pile?
It's misinformation. Check everything. Trust no one.
All true however you leave out the part that shows the EU significantly changed after Brexit / under Von der Leyen, transparancy took a nosedive, debit increased (much more then the UK's) and yes they started doing trade deals again, an thing almost dormant under the UK still in the EU situation.
