First Aspect
If you see a cyclist going impressively quickly later it's bound to be me.I assume that Calstock doesn't count as a western part of Plymouth. I'm going to pass wind and a couple of hours there on the return.
It does not, although it is known in these parts as Hashtock.I assume that Calstock doesn't count as a western part of Plymouth. I'm going to pass wind and a couple of hours there on the return.
Unsurprisingly, the developers do extensive research on what the market is worth. This will impact what they'll pay for land in any given area. Similarly, when it comes to housing mix they will know what is required (and the local authority will have a say as part of the planning application). There is no point spending millions to develop a site if you can't sell the houses.
That development near here where the affordable houses were never built, is still boarded up.
Interestingly, the new builds next to a rail line with miniscule gardens and about 1500 sq ft were going for about £50k more than ours, and £75k more than we spent. Ours is about 2500 sq ft and has over half an acre. If I could afford to, we could probably replace most of the single glazing and tart up the kitchen for the difference, and we'd still have more space and an actual garden.
I don't know how good the pricing is, sometimes. Or perhaps people just look at a new build and imagine that somehow everything that hasn't been used and stress tested yet will be less of a headache than an existing property.
Exactly this. It was the largest they'd done and clearly the numbers weren't stacking up, hence inflated prices and trying to avoid the affordable ones.Probably a relatively small chancer developer, they sometimes get caught out. The big companies generally know what they're doing unless there is some major unforeseen issue like the GFC.
Some houses we looked at either still haven't sold 3 years later, or went for a lot less than originally hoped.
Correct. I am better at some other sports.
That was mass.
I can talk you through the empirical measurement process as well. You need to start with a tank of water....
You have to drown the child to measure its mass?
Can anyone explain this?
Seen today on the M5, about 14 miles north of Worcester.
Damage caused by high winds. Seen it quite often, thankfully not while occurring.
