Gender again. Sorry!
spen666
I previously copied two paragraphs lifted directly from the judgment including the paragraph numbers.
The first, the outcome of the test of the legitimate aim.
Secondly the failure to implement.
Still waiting for the part of the judgement that ruled the trust policy was lawful
As @AuroraSaab says it does not say what you claim it says. you said it ruled the trust policy was lawful. It makes no such ruling at all.
monkers
Pharaoh
As I have explained. They said it had a legitimate aim. In ordinary language of the common man it is lawful. However as I have explained over and over again, that is not the correct word in legal interpretation of the judgment.
As Aurora found, the claim in the submission was that the policy was 'lawful'. I explained that the use of the quote marks that it was placed in showed that it could not be deemed lawful or unlawful, since the legal test is to see if it has a legitimate aim. It is conduct which is found to be lawful or unlawful. The judge found the conduct to be unlawful.
Let's face it, the impact assessment was very poor, no proper attempt had been made for reasonable adjustments following the complaints. The conduct of the management was very poor.
Having read the conduct of the complainants, especially Bethany Hutchinson, this was also very poor - not a winning combo.
The person who comes out of this their reputation more or less intact is Rose Henderson.
spen666
I've worked hard enough on the explanation
You sure have and no one can doubt your effort to argue that black is white and that the Tribunal ruled the opposite of what they actually did rule
but if you are not interested in truth, then I'm not so bothered.
Hilarious from someone who has repeatedly claimed the tribunal ruled completely different from what they did
AuroraSaab
Epic Member
It couldn't be clearer.
The overall TIW policy having a legitimate aim - that of trying to be supportive to transgender staff - doesn't make the policy of allowing access to facilities of the other sex lawful. Quotation marks have nothing to do with it.
I
Ianonabike
A speciality of trans rights activists. I don't bother engaging with clearly bad faith actors, but salute those who get their hands dirty.
Bromptonaut's attempt to throw shade on the judgment was also on the amusing end of the spectrum.
Third spaces.
Retraining for Rose “Why aren’t you getting changed?" Henderson: which door?
AndyRM
Elder Goth
Genuine question, do you know any trans rights activists? Or any women's rights activists? Do you do much yourself?
I suppose I come close-ish to the former as I've helped out with design and print work for a local group, though I wouldn't consider myself an activist.
There's very little evidence of actual activism on this forum (whether it's trans rights related or otherwise).
AndyRM
Elder Goth
I should probably add that I've done similar work for a women's rights group, the Green Party and a communist group.
Also that "Dwarfs Vs Giants" video is one of the stupidest things I've ever seen.
CXRAndy
Epic Member
The irony of using a Christian as an example of someone who doesn't submit to ideology and believes in common sense is wonderful.
Christians don't ram their beliefs down someone else's throat.
They believe in man and woman, overall tolerant.
Common sense beliefs
